Wiring
FoM
I gots a 15" comp vr. The sub is 4ohm DVC. It's running at 2ohm right now, but i'm getting long stretches of shaking bass, and it's not very accurate. Is it due to damping? What is causing this problem? Do I need to run it @ 4ohm or higher?
Username: Joe718
Brooklyn, NY
Post Number: 149
what kind of amp is it and can it handle that 2 ohm load? it sounds like your cant handle that load.
FoM
it's a kx 1200.1 stable @ 1ohm. It's more than enough to handle one 15." It's kinda giving me too much SPL, I want more SQ.
