I need help again
Username: Mikeycaldarone
North Providence, Rhide Island United States
i found another sub i wanted to get i thought was sick. Its a JBL GTIW12 its sick with 4000 watzz peak powering. Should i go with a JBL amp 1200.1 or if anyone else has suggestions thankx
david terran
yeah i would go with the jbl 1200.1 that thing is going to hit like crazy.Is also good to have the same brands like you have. good luck
thanks for your suggestion but im still trying to find the series i want for the JBL anyone have ne suggestions
Post Number: 7
i might get a fosgate would that be good 2?
Username: Udloze
NSW Australia
Post Number: 14
go the GTi series the best
Username: Pat_l
Tucson, AZ USA
Post Number: 606
Fogates are great amps. Good clean power.
Post Number: 8
i might get the Fosgate 1051s- 2 channel amp that wuld be good to right
Username: Fishy
Tamarac, FL USA
Post Number: 227
I doubt you're gonna find a new BP1200.1 but there's a used one on Ebay right now at 150 bucks so far.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5722311351 %26
Kinda scratched up but the price seems right.
-Fishy
Post Number: 9
i think im going to just go with a brand new 500$ fosgate it punches at about 1000 wattz, but on my sub what does 6ohm's mean can i still push it with a fosgate amp thats 2 channels?
