Amp question...
james2004
hey people,
I was just curious i know u can bridge a 2 channel amp into 1, but can you do do vice-versa and split 1 into 2????
Ta very much
James
Username: Pat_l
Tucson, AZ USA
Post Number: 589
You cant.
Username: Jonathan_f
GA USA
Post Number: 1860
Nope. You can, however, run two speakers on one channel if that's what your goal is, as long as you don't go past the min. impedance, usually 2 ohms.
james2004
cheers guys
