What pair of 12 inch subs should I get?
Username: Macdizzlez
Massachusetts
Should I get jl audio w7s, id max v.3, kicker l7s, or what else?
Username: Pat_l
Tucson, AZ USA
Post Number: 608
No brainer W7's rock the boat.
yeh right W7's. THE REAUDIO X*X WILL THE HELL OUT OF A W7 IN THE RIGHT PORTED BOX AND THE RIGHT CAR. G2 reaudio.com 2 look
Username: Southernrebel
Louisiana USA
Post Number: 201
W7's are good, but IMO they are very over priced!
the RE X.X.X. or Adire Brahma can go toe-2-toe w/ the W7 and they arent nearly as expensive.
it all depends on the install!
Username: Symplestiles
Stockton, CA Usa
Post Number: 186
didnt see that the x.x.x. was part of the 3 choices.
Louisiana USA
Post Number: 202
he asks "or what else"
matt 77
lol marshall is right JL is good but to much money to spend id go wit the X.X.X if u want SPL more than SQ and go wit the brahama if u want SQ but still crazy spl from it to
Username: Audionoob13
Novi, MI USA ...
Post Number: 23
W7 If you want to spend the cash, go with a RE X.X.X or Brhama MK II or ID Max is a fantasic sub as well, but i would persoaly go with the Brahma!
