Is this good Specs. for my subs?
Username: Jamesdunn
Post Number: 13
Cone 10" Paper Laminated with oversized foam surround.
Magnet structure 100 oz.
Voice Coil 2.5" High temperature kapton
Power handaling 1000 Watts peak/500 watts RMS
freguency response 35Hz-2.2kHz
SPL 94dB (1W/1M)
impedance 4 Ohms Dual Voice Coil
would those be good Subs or not?
Username: Audiobahn_man
Freakmont, MI
Post Number: 107
what kind are they?
Username: Jamesdunn
Post Number: 14
i just want to no if that would be a good Sub based on just the specs not the name brand.
Username: Jamesdunn
Post Number: 15
Does any1 no if that would be good specs for a sub?
Username: Decde
Post Number: 42
They look like a good sub too me. But like Steven said, whatch out for the brand, cos' the subs might look extremely good in numbers, but if u don't get the right brand, well all that u have in your post is only numbers...
Username: Pat_l
Tucson, AZ USA
Post Number: 600
In car audio the brand means more than the spec's. You could have a sub that has no name (MADE IN CHINA) but has specs of 2000W @ 1000W RMS. But then you could have a good name brand Rockford Sub that has specs of 400W @ 150RMS, that small RF sub will out last, out bump and sound better than that other sub with huge spec.
You see what i am saying. The brand means everything.
Username: Invain
Michigan United States
Post Number: 169
That definitely sounds like an audiobahn sub to me. A 10" that rated at 500 watts rms?
Username: Pat_l
Tucson, AZ USA
Post Number: 603
Yeah, or it could be a sony, because they are heavaly intergrated with Paper Laminated cones.
