THis box good? at least average
Username: Forcesofchaos
Post Number: 27
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14945%26item%3D5721322412 %26
Bad box or is it average or ok for these two subs
2 Shivas 350rms
the boxes depth is bigger then two of those subs Stacked togther by 1/2 inch which means plenty of space behind the subs. thoughts comments thanks.
I like it because its cheap and i dont want to spend alot on a box.
Username: Bdb_86
Bemidji, MN Usa
Post Number: 187
well it is a really nice box but you need to look at the specs for your shivas the air space in that sealed box is 3.3 cubic feet so what do your shivas call for air space recomended for sealed box
