I need Help!!!!!!!!!!!!!!
Username: Mikeycaldarone
North Providence, Rhide Island United States
i have 2 15" Kicker L7's and i need an amp to run it. I need a amp within the price range from 500-600 dollars. Can anyone help me with some names.
Thanx,
Mike
RERT
JBL 1200.1
Kicker kx 1200.1
500-700 on ebay brand new, but watch out for refurbished.
is that ok if the kickers are 4 ohm ?
RERT
Those two are stable @ 1ohm at the 500-600 price range. It will push your L7s well. Also two 15s will drain lOTS of power...how do you plan to give sufficient power to your system? New alternator or second battery? Stay away from capacitors.
ya i realized that now. I might go with the 12"s
