Like
Directed 1100d
Username: Boopers
Lima, Ohio United states
Post Number: 69
accidentally posted this in subwoofer section so I moved it here where it's supposed to be. does anyone know what the true power rating for this is @ 1 ohm. just wondered if the rating is true, under or over.
Username: Boopers
Post Number: 73
well, I won the ebay auction for the directed 1100d, got it for 255. hopefully it's worth what I paid since nobody was able to tell me anything about it before the auction ended.
Username: A3forme
Post Number: 82
Don't have a lot of experience with Directed, but their stuff seems respectable. I don't have any reason to believe it's under-rated, but doubt it's severely over rated if at all. Jonathan is the one who would know.
Username: Jonathan_f
GA USA
Post Number: 1629
It's rated accurately. Good amps, it'll serve you very well and do the power it's rated for. I'm just not as much of a fan of Directed as some, not as good as they used to be, Orion and PPI degraded since they went to Directed as well. You've got a good amp on your hands though, not knocking it by any means. Sorry we didn't get to it in time. Def. worth 255.
Username: Boopers
Post Number: 87
what's normal thd for 1 ohm amps, my coil came apart from my cone and the guy is telling me it's because the amp puts out too much distortion. I don't know why that would be a reason but then again I don't know that it wouldn't be a reason either.
Username: Boopers
Post Number: 93
is .9% thd @ 1 ohm bad or is it average/good?
Username: Boopers
Post Number: 94
Username: A3forme
Post Number: 253
Well, usually class D are all rated at <1% So that's normal. My MTX is @ .421% and My JBL is @ .74%. But, seriously we wouldn't be able to tell the difference in subs. So, no worries man.
Username: Boopers
Post Number: 95
sweet, thanks
Facebook
Shop Related Deals
Directory
