MTX Audio Thunder801D vs. HiFonics Brutus BX1500D
Username: Crappycarguy
Post Number: 22
If you had to choose one of these two amps to run at 2 ohms these are the 2 I am picking out of. Im not just looking at whatever one puts out the the highest watts what would be better on sound quality and be a better quality build etc...
Post Number: 23
come on now guys
Username: A3forme
Post Number: 96
If 800w+ @2ohms is enough power, and you don't plan on using the 1500w of 1ohm power that the BX1500d can provide the definately go for the MTX. Better made amp, more reliable.
Post Number: 24
I need some input here i cant make decisions :-p
Post Number: 25
does it have better sq?
Username: A3forme
Post Number: 98
Well, they are both class D amps....so there is more distortion than a A/B amp. I would say that MTX has better SQ but not so that you'll notice.
Look at the THD of each amp...My 801D was tested @ .421% Most class D amps just guarantee less than 1%. I've never used them side by side so I can't tell you for sure.
Username: Thedirk
Potsdam, NY
class a b D doesnt matter unless your going to a compotion... the normal ear can never notice... thats a bunch of bull in my opinion, i kno alot about electronics, not just amps, cell phones computers, take any amp apart, and you will see inside they all use basicaly the same parts, its all quality in constroction............class my A$$! you cant tell the difference unless its hooked up to a machine!
Username: Southernrebel
Louisiana USA
Post Number: 183
well for high power subs you generally wanna go w/ class D...it has much less current draw than a class A/B...D's are about 80% efficient.
you cant hear the distortion if it is under 10% anyways.
in my opinion the MTX is a better amp, that is if you only need 800@ 2ohms...mtx make good amps
hifonics amps are a little lower quality, but they are good too...mtx is just a little better.
Someone's never had a Macintosh or a Zapco amp...I'd say there's a difference. But I don't know anything....
Username: A3forme
Post Number: 106
Let me clarify. An MTX Class D vs Hifonics class do, you won't notice any difference. Nor an MTX class D vs. An MTX class A/B on a sub.
However, I do believe that when you get into porfessional amps like Zapco, Macintosh, US, IMO you would notice the difference.
Username: Diamond4life
Wisconsin Dells, Wisconsing US
I bought a remanufactured 801d over 2years ago and thing has been flawless ever since, its built solid and lasts along time. Dont know about the Hifonics amp though.
