New member Username: WrestlertreecePost Number: 2 Registered: Sep-04 | Hey Guyz i'm lookin to hookin up a Boss PD4000 amp and i'm wantin to know what are the best subs that i can get for under 100 dollars a piece...spending at the max of $700 thx |
New member Username: WrestlertreecePost Number: 4 Registered: Sep-04 | Or should i just go with a smaller amp? |
Silver Member Username: HeavybHopkins, Sc Usa Post Number: 119 Registered: Jul-04 | that amp is severaly overated |
New member Username: WrestlertreecePost Number: 5 Registered: Sep-04 | what do you mean over rated? |
Silver Member Username: HeavybHopkins, Sc Usa Post Number: 120 Registered: Jul-04 | get rid of that amp if u can. for subs under a hundered dollars a 12 cerwin vega vmax, alpine type r, infiniyt kappa 12.1, and alpine type s. vmax is the best and loudest. |
New member Username: WrestlertreecePost Number: 6 Registered: Sep-04 | Can you give me a couple web sites to take a look at some of those? |
Bronze Member Username: Audiobahn_manFreakmont, MI Post Number: 85 Registered: Aug-04 | EBAY! V-MAX's are 160+ shipping |
Silver Member Username: HeavybHopkins, Sc Usa Post Number: 122 Registered: Jul-04 | at onlinecarstereo.com they are 92 a peice and if u buy 2 shipping is free. ebay has good price on all of them. look at a jbl, kicker, mtx, fosgate, of alpine amp buy mostly the first 3 for amps. good solid power. |
Bronze Member Username: SlimSt.pete, Florida Post Number: 31 Registered: May-04 | www.onlinestereo.com www.acaraudio.com www.woofersetc.com www.hookedontronnics.com just a few |
Bronze Member Username: SlimSt.pete, Florida Post Number: 32 Registered: May-04 | mybad www/onlinecarstereo.com |
Bronze Member Username: SlimSt.pete, Florida Post Number: 33 Registered: May-04 | www.onlinecarstereo.com |
Silver Member Username: A3formePost Number: 176 Registered: Sep-04 | For the Vmax look at www.onlinecarstereo.com. $178 for the 4ohm SVC. For The Type Rs and the Perfects look at ebay. Also consider the Adire Audio Shiva @ www.acoustic-visions.com $125 shipped each. Use the Kicker KX600.1, XTANT A6001T, or the JBL BP600.1 (if you can still find it) to power either set. Get the amps off of ebay. I would go with either the V-Max or the Shive in a ported box. 300W per sub will be plenty of power ported. |
New member Username: WrestlertreecePost Number: 10 Registered: Sep-04 | thx guyz but is that amp i got really over rated? i mean i got the HO alternator.. and all that crap |
Silver Member Username: A3formePost Number: 183 Registered: Sep-04 | Your HO alt has nothing to do with an AMP being over reated. And yes, boss is overrated, and unstable. It's the kind of amp that shuts off after 30 minutes from overheating, no kidding. You'd be doing yourself a huge dis-service by getting anything with the Boss name on it. If you've alrady got, try selling it off. You said you had $700, that should be plenty to get 2 good 12s and an amp. |
Bronze Member Username: HifonicsPost Number: 20 Registered: Sep-04 | get either hifonics 1500d amp and it comes with wiring kit at 300 shipped and get 1 idmax off ebay 350 shipped then you 50 for box. all of this can be found on ebay. |
Silver Member Username: A3formePost Number: 187 Registered: Sep-04 | Or, you can get the Hifonics BX1500D for about 268 off ebay. (shipped) Buy a quality wiring kit from www.knukonceptz.com for $37.50 Get the ID Max for $311 shipped (www.carmedia1.com) That leaves $84.50 That wouldn't be my choice because I would have a good custom ported box made, but thes are better prices for that option. (prefab) |
Bronze Member Username: WrestlertreecePost Number: 18 Registered: Sep-04 | thx guyz!! i'll look into all this |
