Alternator help
Username: Ukw10
Post Number: 22
where should I look for ampere of my alternator.
Username: Ukw10
Post Number: 23
I have pontiac sunfire and have factory alternator. Is that enough for 250w X 2 System??
I only have radar detector and 55W fog light add to it.
Username: Glasswolf
Post Number: 272
you can call any local auto parts store and ask them.
your system and those lights are drawing 47A of current.
Username: Motoman22
Post Number: 8
My Linear Power 5002 (250w x 2) pulls upwards of 80amps at 4ohm stereo when cranked.
You cannot determine power demand based on claimed power output. Sorry.
Username: Fillymo
Post Number: 8
I have a 1991 Chrysler Newyorker Fifth Avenue Wondering how good my altenator is. Gonna be Running a Class D bp1200.1 Jbl or where i can find out how much it supplies
Username: Motoman22
Post Number: 9
FillyMo, I know you didn't ask the same question as the first in this post. If so, the answer is the same as the second in this post.
Username: Glasswolf
Post Number: 290
Incorrect, Mr. Bates.
That's Ohm's Law at work. P (watts) = I (amperes) * E (volts)
If the amplifier is accurately rated for it's RMS power, then the calculation is easy. In the case of underrated amplifiers, the law still holds precisely true, and RMS output can be found through the use of a dummy load and an oscilloscope. JL Audio amplifiers are a good example.
The 500/1 actually puts out about 670wRMS.
I was giving him a ballpark for current draw so he'd know how much of an increase he'll need in alternator current.
What I can't calculate for him is how much of his stock alternator's current is used by the car itself.
That changes from car to car.
Username: Motoman22
Post Number: 18
Until you can find me an amp that is 100% efficient, you can't rely on these calculations to determine the power demands of an amp.
How about heat? Ever seen an amp that does not waste power producing heat? The heat comes from somewhere and that's consumed power....which Ohm's law does not take into account. The 80A + that my 500w amp draws is just one example of many.
You still can't determine the actual power draw of an amplifier based on output...not outside of the classroom anyway.
Username: Glasswolf
Post Number: 316
heat is still energy. you cannot create, or destroy energy. it merely changes forms.
Now please stop being a troll.
All you need to do to see the current draw of an amplifier is look in it's manual.
It's always listed there.
Username: Motoman22
Post Number: 22
Ok, let's recap this... based on the claimed power output of an amp and some fog lights you determine the consumption of an electrical system.
Wolf:
"your system and those lights are drawing 47A of current."
Moto:
"You cannot determine power demand based on claimed power output. Sorry."
Wolf:
"Incorrect, Mr. Bates.
That's Ohm's Law at work. P (watts) = I (amperes) * E (volts)" 'blah blah'
Moto:
"Until you can find me an amp that is 100% efficient, you can't rely on these calculations to determine the power demands of an amp." 'blah blah'
Wolf:
"heat is still energy. you cannot create, or destroy energy. it merely changes forms.
Now please stop being a troll."
Glasswolf, these formulas take neither heat nor the substancial energy consumed by heat into account so I say again,
Saying my post is incorrect is innacurate and misleading information, that is my only issue here besides the personal and equipment attacks you have been passing off on others seeking help.
Call me a troll all you want, doesn't change anything. I've been helping people on here for over a year and if you can find me a bit of information I have passed off as fact which is untrue I'd love to hear about it. Good luck.
Merry Christmas
Username: Glasswolf
Post Number: 329
If people say "is this stuff any good" and it's garbage, I'm going to tell them.
get over it.
I'm done with this thread.
further debate will accomplish nothing.
Username: Chippa
Post Number: 25
Thanks for not turning this thread into an argument Wolf
Username: Glasswolf
Post Number: 356
well, I can agree to disagree.
I can estimate efficiency easily enough based on the amplifier class, which is simple to do.
I did miscalculate though since I didn't account for two driving lights at 55W each. I was thinking 55W total when I added that up.
anyway, that's that.
On a side note, another way to estimate max current draw for an amp is to look at the fuse rating that came with the amplifier. no matter how inefficient the amp may be, it cannot draw more than the fuse will allow without blowing the fuse. If the amp maker has a decent product, they will match the fuse fairly close to the max current demand of the amplifier. Then you just need to divide down for the load on the amp.
Blah
I say, just hook everything up. When crap starts blowing up, then you know you need a bigger supply of power.
Username: Glasswolf
Post Number: 424
that's one way to do it.
hehe
Username: Its_bacon12
Post Number: 37
rofl
