Wires upgrade???
Username: Decde
Post Number: 121
Hey guys, i was just wondering, if i install my 4 6x9 in my car, will i have to change the wiring that came with the car?? It's the first sound system that i'm installing, and the wires for the speakers is still the factory wiring, .65 i presume, or something like that. Should i put better wiring??
Username: Pete0403
If you're using an amp, probably. But if you're wiring them to your HU then you can use the factory wiring with good results. (as long as their in good conditions)
