Are Phoenix Gold amplifiers recommended?
I was wondering about the qaulity and power of Phoenix Gold amplifiers. Would it be a good idea to go with a R5.0:1 mono amp for two earthquake tens rated 220 watts each?
Username: Koz1031
Monticello, In United states
Post Number: 131
Did you get the db series?
Username: Koz1031
Post Number: 132
just slightly overpowering them. but you should be ok. i believe you will have to run those subs in parallel to get them down to 2 ohm. as that amp is 2 ohm
http://www.phoenixgold.com/2004/octane-ramps.html
Yes I have the DB10's 220 watts rms. Isn't this amp rated 400 watts rms at 2 ohms so wouldn't this be slightly underpowering them?
Username: Insearchofbass
Post Number: 603
phoenix gold makes good stuff but the octane series is ok but the tantrum stuff is better also check out the mtx stuff its cheaper than the phoenix gold stuff (mtx 1501d or the mtx 81000d)
Post Number: 604
whoa wait this is for two 10s 220 watts each man also i didnt realize the octanes rating was peak
Post Number: 605
youd be fine with the octane on those 10s like koz said
I hear that MTX are pretty good amps. Would they be comparable to the Xenon series from PG or the Kicker KX400.1? How do these three amp manufacturers compare to one another? Thanks
Post Number: 606
they are all pretty close in performance to each other
alright then thanks for the help
Post Number: 608
your welcome
