Like
Amp decision quick pleasE!
Username: Aznsoccerstar11
im dying without a system, I just want a better am then my rockford 700s
Ok I have a simple system. Just 2 Kicker Comp CVR 12's at 4 ohms. I know there are many choices but could anyone list their favorites to tun tese 2 subs?
RMS Power Range (Watts) 50-400
Peak Power Handling (Watts) 800
My budget is small sorry. I mean anywhere upto 300ish, I know I can find good ones ebay so it doesnt matter. Just list your favs. If you have really cheap place thats cool too.
Username: Jonez788
Post Number: 109
I have those subs running at 2 ohms off a Kicker KX 800.2 Got it off Ebay.
Username: Zacdavis~
get a SPL 1600w amp, they're only around 200 bucks, plus it'll do 700 rms bridged at 4 ohms. thats what you want. run you subs in series(8ohms each) and then parralel,(back down to 4ohms mono). all spl amps from series 1 up to series 4 are all the same inside, the only diff is the cases, trust me, they slam.
so the spl 1600 will power my 2 subs better than my rockford fosgate 700s did with 175x2 at 4ohms?
Facebook
Shop Related Deals
Directory
