Are these subs decent? SOUNDSTORM.....
I'm just wondering if these subwoofers are good...... Sound Storm DC-112DVC 900W 12" Cast Frame DVC 4 Ohm Subwoofer.
900 watts peak power
450 watts continuous power handling
120oz magnet structure
Frequency response 28Hz - 2kHz
4 Ohm impedance
SPL 1 watt/ 1 meter 96dB
Silver injected cone
2 1/2" aluminum voice coil
Butyl rubber surround
Ferro-fluid enhanced
Mounting depth 7 1/4"
so how are these?? and is the brand ok?
heres the picture http://www.hifisoundconnection.com/dc112dvc.jpg
Username: Heavyb
Hopkins, Sc Usa
Post Number: 117
no nothing soundstorm is good give us ur budget and we can make recomendatioins
lol my budget is like $100 for 2 subs lol
Username: Bryanwalsh524
anyone else?
Username: Zacdavis~
Post Number: 19
they'll work, just try'em if u don't like'em sell'em, btw the best amp they make is the f700.2
Username: Insearchofbass
Post Number: 596
ill sell you my lanzar dc 12s (old school) used $100 plus actual shipping 350 rms each
Post Number: 597
2 of them 4 ohms each....single voice coil
Post Number: 598
i had the sound storm 350.2 for get by amp big piece of junk shuts down all the time even had it replaced with a new one that one did it too
Username: Zacdavis~
Post Number: 21
really?, i've seen those run 2 ohms bridged all day long, maybe you just got a bad one, ?
Username: Koz1031
Monticello, In United states
Post Number: 133
apparently he had two bad ones if he got it replaced only to have the same thing happen.
Post Number: 600
i sold the amp to a guy at my friends work and told him up front about it shutting off after getting hot and it did it in his car too after it was on a while and this was the amp that i got to replace the first 350.2 soundstorm amp .....I got it because it was cheap at the time with a 5 year warranty but i can also tell you this it was lucky if it pushed out 200 to 250 rms based on other amps ive had
