Alpine Type R or Inifninty kappa perfect 12.1???
Username: Outlaaw
which subs would yall go with???
The question is how much are you will to spend and what wattage range are you looking for?
Although alpine are good with their HU and Infinity are good with their Speakers, I think you would be better off with something else for subs. Just ask around for better subs.
"The question is how much are you will to spend and what wattage range are you looking for?
Although alpine are good with their HU and Infinity are good with their Speakers, I think you would be better off with something else for subs. Just ask around for better subs."
ask around for other amps too
Username: Heavyb
Hopkins, Sc Usa
Post Number: 116
both are good sq subs but not very high in spl. i personally dont think they are different. i like the infinity a little more though
