My amp wire
nobody
If your amp has 4 Gauge power/Grounding connection, do I need to use 4 gauge wire?? My amp rating is 100 X 2 RMS.
Username: Glasswolf
Post Number: 698
for 200 watts, 8AWG should be sufficient depending on the length of the cable.
here's a chart:
http://www.the12volt.com/info/recwirsz.asp
