LOUDER THAN 2 S15L7??
I LIKE *LOUD*
does anybody kno any 2 subwoofers that would be louder than 2 s15l7 solobarics?
Username: Glasswolf
Post Number: 811
sure. look at the RE triple X subs.
use the quad coil models, and stick one amp on each coil and max the subs out.
JL's 13W7 subs with dedicated 1000/1 amps will give a run for the money too with their 32mm one-way Xmax
I LIKE *LOUD*
what kind of subs are the RE triple X subs
Username: Glasswolf
Post Number: 818
Resonant Engineering.
http://www.respl.com/
Username: Bass_lover
Post Number: 11
also look at Fusion Jona Luma subs, 2 of these and 2 Jona luma amps in a car easily became the loudest car in New Zealand.
http://www.fusioncaraudio.com
