Replacing a DVD player within a surround sound package
Username: Amateur_hour
Toronto, Ontario Canada
Is it relatively easy to replace my DVD player( part of a mini system, DVD player is also a reciever) with a new DVD player.
The player I have now has no progressive scan or component video inputs but I like the speakers and sub.
Or is it easier to just buy a new surround sound system.
Thanks
Username: Project6
Post Number: 1133
What system are you using now?
Pioneer..not sure the exact model number but its about 2-3 years old. The package includes the DVD player/receiver, five speakers and sub plus a display unit that plugs into the the DVD player.
I am concerned that a new DVD won't have the connections to plug into the sub or for the display.
Username: Project6
Post Number: 1160
What kind of audio inputs does the pioneer have? That should be your concern right now. Most decent DVD players will have 3 kinds of audio outputs, optical audio, digital coaxial and stereo. If your receiver can accept one of the digital outputs, then buying a new dvd player should be no problem.
