No sound from TV when playing DVDs
Username: Yendor35
Hi I have a Panasonic 3dTV and was using a Panasonic btt-260 3d blu ray home theatre system. Once it was all set up it worked perfectly. I could use the tv to change the sound from the home cinema to just the tv and vice versa.
Recently the blu ray player decided to go wrong so I have now bought a Panasonic SC-BTT560EGS. Which apart from the looks it's does exactly the same as my other player. But for some reason I cannot get the DVDs to play the sound though my tv, it plays fine though the home cinema system. I have the hdmi cable going into the tv the same as last time but it does not matter what I try nothing can change the sound to the tv. I have even bought a optical cable hoping this would sort the problem.
I have read and reread the manuals and nothing has helped.
Also when I try and do the Viera link setting it sometimes says check cables and another time it won't.
Any advise on what I can try now would be great.
Thanks
Rod
Need to Register?
Forgot Password?
Enable HTML code in message
