Samsung LED Smart TV/Pioneer DVD player to Pioneer AVR
Username: Jre
My Samsung LED TV has an optical audio output.
So i connected the Audio optical out from TV to AVR Optical INi believe this is correct. i noticed the sound quality fading and coming back to its full potential, is this due to channel audio quality right or is it due to optical cable that i am missing something?
The DVD player is hooked up to the TV via HDMI cable, then based on above audio out from my TV to the AVR. I believe this is right connection, question is will the AVR be able to throw out true dolby surround sound?
Then i have the settop box which is hooked to TV for various channels for which the audio output is again from TV to AVR.
Thanks for your valuable support
Need to Register?
Forgot Password?
Enable HTML code in message
