Upgrade Speakers
Username: Lee64
I am trying to replace my speakers, quite a cheap set currently with one broken.
I have a large room, 26 by 28, rec room. I want a good sound without thousands of dollars. I have spent hours searching but I can not determine the best setup for my room or determine the watts i need. Not my area of expertise.
What I do need is wall mountable... One in the front and one in the rear require wall mounting.
I would appreciate any help I can get. My price range would be up around $750.
Thanks in advance
Username: Vm8444
TorontoCanada
Post Number: 434
http://www.amazon.com/MartinLogan-MLT-2-Theater-System-Black/dp/B0049P2000
Or Polk audio 40's
Or energy take classic though small sound large
Or Boston acoustics
C23 or c26
Check amazon or newegg.com for all
Username: Erick2983s
hello, How to upgrade speakers.
thanks..
Need to Register?
Forgot Password?
Enable HTML code in message
