Sound from tv
Username: Mackman22
ok hey all i hooked up my surrond sound what i want to know when i play it is the sound supposed to be coming from tv speakers too because mine is and it sounds like a echo and if not any suggestions thanks tony
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 1147
The TV speakers should not be on
Username: Mackman22
any take on what im doing wrong here or why it would do that
thks tony
Username: Jrbay
Post Number: 1151
Greetings Tony,
There are delays happening between the TV speakers and your surround sound system. If you can turn off the TV speakers then problem solved, if not do you have a cable/satellite box? If so, taker the audio out of that directly to the surround system. That is the preferable way to connect for the best sound.
Username: Nency
Post Number: 9
yes... try to take set top box audio direct to your surround system.. it will work.... may i know which surround system. you have ... ??
Username: Mackman22
ok thank you jim aand nancy got it too work right and nancy i have a phillips hts 3440 nothim system not a top of line system but it serves my needs now to hook up xbox and ps3 with a coax and splitter lets see if i can handle this one lol thks again
Need to Register?
Forgot Password?
Enable HTML code in message
