Home theater system cables - help please!!
Username: Msangan
HI,
I have got a one supersonic home theater system (SC25DVD). Unfortunately it does not comeup with DVD player and sub-woofer interface cables. Here is the image of subwoofer input port (Fig-1: with 9 pins input port) and DVD player outputs (Fig-2). Can you please recommend what is the cable type suits for connecting DVD player to sub woofer. Also where can i buy this.
your help highly appreciated..
Thanks
Username: Vm8444
TorontoCanada
Post Number: 229
Junk no offence
can you sell it or take it back I say ,
get a reciever then connect speakers cable box dvd etc to that.
http://www.dakmart.com/p11034/SLED-DENON-AVR-1709-7.1-SURROUND-RECEIVER-AUTH-DLR -W-WT/product_info.html
and if you can't use your speakers these are very good.
http://www.dakmart.com/Audio-Home-Audio-Home-Theater/c4_9_10/p11311/Boston-Acoustics-Horizon-Series-MCS100-MDNT-5.1-Speaker-System/product_info.html
theaudioguy.ca
Username: Gvsgajuu
hii......i have 5.1 Philips DVD home theaterHTS3152 .......i have connected it with TV & laptop.....but only front2, central1 & sub woofer1 are working.........both rare2 speakers are not working.......PLZ help me out
Need to Register?
Forgot Password?
Enable HTML code in message
