LG 47LH90 47-Inch As a PC Monitor
Username: Binar
Fellow Forum Members,
I'm thinking of buying an LG LED 1080P 47" flat screen TV that is going to double as my computer montior and it is shown here:
http://www.amazon.com/LG-47LH90-47-Inch-Backlit-Infused/dp/B0026NSWSQ
The highest resolution my video card supports is 2560x1600 and the LG flat screen supports a resolution of 1920x1080.
My question to anyone out there relates to whether the LG flat screen is able to support a Windows XP desktop at 2560x1600? In other words, is the maximum resolution the LG flat screen can support dictated by my PC video card or is it dictated by the max resolution the LG flat screen TV can support? Any info will be greatly appreciated. Thanks.
Username: Lion_cing
Post Number: 44
do little research... if i were you I will wait for the new system. double the 1080p. resolution.
and for you question. Your tv will only receive 1920 x 1080. and that's what you will be watching
Need to Register?
Forgot Password?
Enable HTML code in message
