TV to HTIB - No Surround Sound
Username: Gras4
I'm getting Stereo-type output when i route TV Audio to HTIB.
* Cable connection to TV (in India, DVRs/Set Top Boxes are usually not used unfortunately)
* TV Audio Out to HTIB Aux IN
TV -> LG 29FD5RGE; HTIB -> Philips HTS3152/98.
Is there something that can improve the situation in this configuration?
Will going for DTH help (especially in the Indian context)?
Username: Massbrandon
From what I know, the best way (and maybe the only way) is to use an Optical audio cable. That should give you surround sound.
Need to Register?
Forgot Password?
Enable HTML code in message
