Making TV sounds come through the surround sound system
can i do this and if i can how
Username: Jdsaenz1
Post Number: 12
How do you mean? Like connecting your TV's audio out to your surround system's receiver?
the DVD plays through teh TV adn sound system fine but is there a way to make the TV stations go throught eh surround sound system
Username: Jdsaenz1
Post Number: 17
ah, I see. I think it depends on your surround system's capabilities. For example, the Logitech z680s I use can give standard tv channels' audio (which is usually in stereo) a 5.1 effect with Dolby ProLogic or ProLogic 2, so that 'stereo' sound can imitate '5.1 surround sound'. There may be settings on your surround system that you can play with to incorporate ProLogic into your TV audio.
