Dish Network
Username: Djoc
I have a 510 DVR which have had four about 4 years. With optical plug in back I hooked to my stereo but am not getting digital sound. Should I be? The manual says to look at programming guide to see sound quality but it is rarely listed.
Username: Arande2
400dB could probably d..., SouthWest Mi... Too Many DBs...
Post Number: 1181
Yeah you have to set it to output digital audio.
I have a different one but I went into the menu and went to audio then set it to Dolby Digital/PCM. I don't know if your stereo can handle DD but I'm pretty sure it'll take PCM.
Username: Djoc
I checked and it is set for digital/pcm. Do you get digital sound?
Username: Arande2
Post Number: 1185
Yes I do. What is your stereo? You have to make sure everything is set correctly.
Username: Djoc
I have a new Sony receiver. I have an optical cable from the back of the dish receiver to the stereo. I get PCM no prob but wondering why I don't get Dolby digital. I do on my dvd player.
Username: Arande2
Extreme SQ FTW
Post Number: 1683
I should remind you that you only get Dolby Digital when you're watching a movie (says DD in info), like PPV. Just look at the PPV channels and you'll find ones with DD.
Username: Djoc
thanks. I thought the ones that said stereo were also in dd. My bad.
Username: Samijubal
Post Number: 3318
The premium networks, HBO, Showtime, Starz broadcast some movies in DD. The guide will say DD on the ones that are.
