Pioneer vs. Kenwood
I am looking at getting a Home Theater Receiver. I have a DVD player but I am in the market for a receiver. The two receivers I am looking at are the Pioneer VSX-D412 and the Kenwood VR-705-S. The two are about equal in specs and price at Best Buy. I was wondering if anyone could give me some advice which would be the better buy.
Thanks
Username: Iceberg
If i would pick between the two i will take the Pioneer. I really like the way pioneers sound. How much are you going to spend? did you look at other models in the same price range? Denons maybe?
I just purchaesde the Pioner VSX-D412 @ Circuit City For $149.00 Jan. 04, 2004 and i love it. Sound is great, set-up a breeze. Have it hooked up with a DVD-VCR combo, and 31"RCA TV with A/V. Along with 5-speaker system. Used Monster speaker cable and also purchased the Pioneer 3 speaker set for $71.00 so far it all sounds great.
thecraft
Pioneer
Don't ask why, they just kick a**.
j
neither try the Onkyo HT-S760 for $499 or the Yamaha HTIB for the same price.
Username: Gdawg
Post Number: 104
Anon,
Dont buy from Circuit City or Best Buy, shop off the internet, you will find WAY better deals.
For Example, the THX Certified Kenwood VR-6070 available from ecost.com for 195$. I would recomond this for your setup. Much Much better than either the 412 or 705-s.
I have used this receiver myself and that is why I recomend it to a person seeking a low budget HT System.
Link:http://www.ecost.com/ecost/ecce/shop/detail.asp?dpno=149556
Note: If you want to spend less, then there is a VR-6060 available from the same website for 129$.
Have Fun Searching!
G.DawG
