PARADIGM QUESTION
Username: Eros_992
West Hills, California USA
I want a 5.1 paradigm system. I have a budget which brings me to my question. My local dealer is pricing the studio v.3 lower to make way for the v.4's. I am a music 2/3 and video 1/3 guy. I am considering the following system (all v.3):
Front's: studio 20's
Center : cc470
Rears : adp170's
Sub : PS1000
Here is my concern. Am I blowing it getting the ADP170's instead of the adp470 rears at about twice the price? Is the system I am considering a decent fit? This will probably be powered by a Yamaha 2500
Username: Project6
Post Number: 11652
You can't go wrong with the Paradigms, newer version or not.
Username: Eros_992
So you don't think the adp170's are going to be a big issue re "seemlessness" in surround with the larger studio 20's and cc470 (center)?
Username: Project6
Post Number: 11662
It will certainly do well for the surround job and will integrate well even with the bigger mains.
Username: Gavdawg
Post Number: 39
The ADP170 is still going to be matched up to the studio20. You may hear a difference if you intentionally listen for it, but it wont be that severe.
The timbre and pitch will still be correct, but there may be some resonance in the enclosure and the bass response will not be as deep, but as I said, you will have to listen for this if you arent trying to.
This is still a great surround speaker, and does its job well.
If you needed to cut the cost in a specific speaker but wanted to keep the timbre correct, that was the proper one to do it with IMHO, especially being that music is your forte.
Username: Gavdawg
Post Number: 40
and the v.4 is significantly better than the v.3 studio series to my ears. The tweeters are significantly smoother and sweeter sounding.
Username: Gavdawg
Post Number: 41
not saying that the v.3 is a bad speaker, but I prefer the v.4. I would audition the v.4 and find out what you prefer if you can
apologise for the multiple posts
Username: Eros_992
Berny and Gavin: Thank you so much for your input on this!!! When I finally get set up and burn them in, I'll give you folks a follow up.
Username: Project6
Post Number: 11740
Did you get the Paradigms yet:-)
