Boston Acoustics CS2310 vs Energy 5.1
Username: Heyjoe91
Hi All,
I was looking to buy the Energy 5.1 ($400) for my 15x20' room. After adding in a receiver I was above my budget. I am pretty sure that the Energy speakers are clearly better than the Boston Acoustics ($200) but by how much? I'm not a crazy audio guy but I would like something better than a cheap HTIB. Given the size of my room and my small budget will the BA setup be any good. I heard the speakers are good but the sub is under powered for a 10" speaker. I know this is all subjective but just curious what others think. Either way I'm only going to spend about $150 on a receiver so maybe the better Energy speakers won't even pay if I'm using a cheap receiver anyway. Thanks for your help.
Username: Vm8444
TorontoCanada
Post Number: 403
Hi there go with ba
Ive used both and the ba probably sound better then the energy with a cheap reciever.(why garbage in garbage out remember)
Im guessing here cause of the soft dome kordec tweeter should tame brighter highs from crappy receiver.
Need to Register?
Forgot Password?
Enable HTML code in message
