Audio input to SONY DAV-DZ100 - IS it possible? Help?
Username: Meathome
I have read conflicting messages about the ability of the SONY DAV-DZ100 to handle audio in, say from a set top box, through the one and only SCART on the receiver. Does anyone have a definitive answer as to whether it can or can't before I unpack and set it up? I bought it from Amazon who misquoted it as having 2 scarts which it doesn't.
(PS Sorry for the other miss-post)
linhly
hi the dav-dz100 has two verion one with two scart and one with only one scart the one you got will. not be able to hook up with you freewview.
Username: Meathome
Thanks. I'll send it back and go for the DZ300. I thought the DZ100 was too good to be true!
Username: Bigbrook865
Well you could actually do it using the rf aerial socket on the amplifier. You need to connect the output of the freeview to an fm transmitter, such as the ipod generation ones, and the amplifier will pick up this frequency. Any other questions let me know on bigbrook865@hotmail.com
