Paradigm Cinema 110s vs. BIC Acoustech
Both are about $800. Any thoughts?
Username: Baseballfan
I've had the Acoustechs for about a year and a half now, so take my opinions with that in mind.
Paradigm:
Pros: Can wall mount the front sound stage. Left/Center/Right are identical speakers.
Cons: Speakers only rated down to 120Hz, which makes for kind of a high crossover point to the sub.
Acoustech:
Pros: Speakers all go low enough to cross over to the sub at the standard 80Hz. Excellent sub for a budget system.
Cons: No bookshelves available for mains, only towers (if space is an issue).
If space is an issue or you like the looks of the Paradigms, I'm sure they are a decent speaker package. My biggest concern would be the high crossover point.
The Acoustechs use horn drivers for the mid\highs (2100Hz and up). Some people *hate* horns, others swear by them. The horns also make the Acoustechs more efficient, meaning it will take less power to drive them to the same sound level compared to the Paradigms.
SerenityNow
Thanks very much. This is useful information.
