HELP! Loudspeakers for Harman Kardon 635!
Peter Verebelyi
Hello!
I am planning to buy a Harman Kardon 635 amplifier and am currently looking for an appropriate speaker system (7.1).
Maybe you can help in the decision.
Since my "budget" is quite limited (and also the room is quite small, 4x5m meaning 12x15ft), I'd
like to buy a system that matches the amplifier
in performance and sound quality, but is small enough and affordable at the same time.
I had some ideas in mind: HKTS14, JBL300, Aperion 422, Polk RM6900, KEF 2005 (seems to be to expensive for me).
Could you please recommend something? Or any combination of speakers/subwoofers what to buy?
I am also thinking about building a speaker system, buy I think without much experience it can easily be a waste of time and energy.
The system is primarily for home theater, but also for CD listening.
Thanks in advance for all responses (or links, reviews, tests that might help in the decision)
Peter
Username: Project6
Post Number: 3412
From your list, I like the Aperion and KEF. Have you listened to any of these? Your ears are the only ones that matter.
Username: Quinn
Post Number: 51
Look at Ascend Acoustics too.
Try Axiom M3s
