A good sounds system for 200 or less
Greggs
i just want something kind of basic.. but still get the effect... i might check circuit city cause they have a room to try them out.. what is a good brand t hat isn't real expensive...
Greggs
can u get any good deals from this site by a good sounding brand??
http://store.factoryprices4u.com/klhmp06ht.html
http://store.factoryprices4u.com/audio-speakers-home-theater-packages.html
ChrisWhyte
Try eBay. I got an Acoustic Solutions DS1233 for £60. Its worth £170 in the shop!
Username: Dmwiley
Post Number: 785
Depends on your definition of "good". At 200 you may be stuck with brands like Sony, Panasonic, Samsung,etc. Better choice would be Onkyo or Yamaha if you can find an HT system around 200.
Username: Malco49
Baltimore, Maryland Usa
Post Number: 9
don't laugh but i got a pretty smoking philips mini system(20 watts per) for just over 50USD at best
buy.
Josh4213
Chris, can you tell me if the acoustic solution DS1233 is any good, as im thinking of getting one myself.
Username: Monolgoue
Post Number: 67
no one got a pretty smoking anything for $50
Username: Edison
Glendale, CA US
Post Number: 771
This executive system for 1/3 of the original price !
This looks classy as well.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5789657133&category=4787% 26%26
I have 3 of them. They really sound better than anything out there for the same money.
