Onkyo 570
I have a question with my setup. I have digital cable, dvd, sony wega tv, and onkyo 570. How should I set this up? What should I connect to what?
Username: Dmwiley
Post Number: 584
First, try reading the manuals. Then ask if you run into difficulty.
margo
from digital cable box-run optical out to onkyo optical in, run component video out to wega component video in
from dvd-run component video out to wega component video in, run coaxial audio out to onkyo coaxial audio in (since this is default for onkyo dvd audio setup)
this should do it. let me know if forgot something
charlie01
Thanks Margo.
Here's what people advise me to do. Can I change dvd audio default setup?
DVD:
-video(component connection if available, otherwise s-video) directly to the tv
-sound(optical digital cable) into the reciever
CABLE:
-video(s-video) directly to the tv
-sound(digital coaxial cable) to the reciever
margo
yes, on unit press the dvd button
on unit press digital input and coaxial appears
press digital input again and optical appears
if in future you want coaxial again, the digital input button will cycle back to it
enjoy!
