Home cinema DVD problems
bazil
Hi
I have recently purchased a Sony home cinema system (DAVSB200). When I play DVD's there is a line gliding across the screen and sometimes a kind of shadow going across the screen.
Any ideas to whether this would be the TV ( also Sony)or the DVD player itself.
Username: Project6
Post Number: 2501
check your video cables.
bazil
What are video cables?
I am having the same problem (i.e. lines gliding across the screen) with the DVD-R, the other DVD movies i purchased are working just fine though...and yea the color is not showing either...(it is black and white)
