F.S. Digital Designs 3512d Dual 2 Ohm & DD M1A
Username: Cried
Erie, PA US
Post Number: 620
ForSale: Digital Designs DD3512 + CF DustCap
Power Handling RMS/Peak: 1200/4800
Nominal Impendance: Dual 2 ohm
I have had this sub for just over a month and it has very low hours on it. My car was in the shop for awhile with several issues and I was without bumps for a few weeks. The sub is in phenominal condition and is 10/10 all around! It is flawless and was never clipped. Run off a Digital Designs M1a, the Gains were adjusted properly and has never been abused. It was in a kerfed ported enclosure 3.5cubes @ 38Hz, and absolutely pounded without loosing its sense of quality. Reason I'm selling is because I have had my eye on the 12HDC3 and AQ1200D, so this and my DD M1a are both up forsale.
SUB: $290 Shipped/PP'd
Price is approximated, so email me with zipcode for most accurate price.
I bought this beauty from a guy on soundpressure. I have had it just over a month and very low hours have been on it. My car was in the shop for awhile with several issues and I was without bumps for a few weeks. This amp has continued to work flawlessly and is in prestine condition both physically and mechanically. Gains were adjusted properly and has never been clipped. It pushed my 3512 unbelievably well! Reason I'm selling is because I have had my eye on the 12HDC3 and AQ1200D, so this and my DD 3512D w/ CF dustcap are both up forsale.
AMP: $305 Shipped/PP'd
If you have any questions or concerns, feel free to pm me, or drop me an email at j_c_wheeler8@hotmail.com Thanks a lot and Happy Holidays!
SPECIFICATIONS
Series: M
Input Sensitivity: 0.2V - 8V
Subsonic Filter: 10 Hz - 50 Hz at 24 dB/Oct
Variable Low Pass Filter: 20 Hz - 200 Hz at 24dB/Oct
Clipping Display: LED
Tested Voltage: 14.4V
Tested THD: 1%
Model: M1a
Damping Factor: 250 @ 1 ohm
Power at 1 ohm: 1200W x 1ch
Power at 4 ohm Mono: 300W x 1ch
Max Dynamic Power: 2000W x 1ch
Efficiency thru Output: 75%
Dimensions - inches: 11.81 L x 9.25 W x 2.1 H
Signal to Noise: 85 dB
Shipping Weight: 12lbs
Username: Cried
Erie, PA US
Post Number: 626
bump
Username: Cried
Erie, PA US
Post Number: 628
up
Username: Cried
Erie, PA US
Post Number: 660
When uninstalling this sub about a month ago, I found this tiny mark on the surround. It is barely noticable I only saw it because I had a flashlight out trying to find the screw heads. Nevertheless, I thought it was imporant to point this out. I need this sub gone and will part with it for....
$260 shipped if you live in Indiana, Kentucky, Illinois, Ohio, Michigan.
$270 shipped, if you live elsewhere in the continental 48.
Username: Cried
Erie, PA US
Post Number: 661
up
Username: Bonhamd
Northern, Michigan USA
Post Number: 274
still have the amp?
Username: Denali_on_22s
The kids love my rhyme...
Post Number: 4293
it prolly has water damage... rofl
Username: Cried
Erie, PA US
Post Number: 662
reecie pieces prolly has down syndrome. fyi
Username: Peakohm
Post Number: 21
pm'd
