12" Hifonics HF Dual 4 Ohm SUBS Brand New $80 pr.
Username: Cosmiccaraudiocom
Gallatin, TN United States
Hey all,
I have several sets of Hifonics HF12D4's. I bought these on closeout, and am really looking to move them quickly, thus the LOW, LOW price on them.
The retail price on them is $149.00 Each, get them while I got them.
HF Subwoofers HF Dual VC round profile with Low-Q, Theile/Small parameters perfect for small sealed or vented enclosure designs. The single 4-Ohm voice coil HF version is used most often in subwoofer enclosures with two or more drivers, enabling low-impedance amp loading, without giving up vital cone area. More cone area translates to more SPL.
HF Subwoofers offer "The Power of 1" Reliability. The answer is; HF's integrated spider assembly and tinsel lead-in wires. The Hifonics one-piece spider-tinsel lead design eliminates one of the most common modes of subwoofer failure, the dreaded tinsel lead breakage. And when the "heat is on" the Hifonics heat-dissipating aluminum CCAW voice-coils disperse the left-over thermal energy into the magnet & frame assembly. You need Hifonic's integrated tinsel leads, if you want sonic reliability.
Specifications:
* 700-Watts Maxximum Power Handling
* 350-Watts RMS Power Handling
* Dual 4-Ohm Voice-Coils
* For 2-Ohm and 8-Ohm Applications
* Silver Laminate Cones
* Polypropylene Dustcap
* Chrome Speaker Frames
* 40oz. Single-Stack Magnet Assemblies
* 2-inch 4-Layer Aluminum Voice-Coils
* One-Piece Spider-Tinsel Lead Designs
* 1.1" Wide Reinforced Rubber Surrounds
* Nickel-Plated Back-Plate & Push & Insert Terminals
* Vented And Sealed Enclosure Compatibility
* Watts Peak Power: 700
* Watts RMS Power: 350
* DVC Imp./Ohms: 4 + 4
* Fs - Hertz: 30.57
* Re - Ohms x 2: 3.6
* Qts: 0.527
* Vas - Liters: 121.7
* Vas - Cu Ft.: 4.3
* Xmax - mm: 11
* Xmax - Inches: 0.43
* SPL - dB @2.83V: 89.5Upload
