Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1537 Registered: May-07 | It's Finally time, i thought it be easier to link to my build pics then repost, so heres the link. http://www.facebook.com/album.php?aid=86275&id=507160478 Parts list Motherboard Asus M3a78 - T Ram 4 Gigs G Skill Ram Case Antec 900 Drives Lg Blu - ray player / DVD /Cd burner Lg Dvd / CD burner with light scribe Hp dvd burner/ cd burner Hdd 1000 Gig Seagate Sata drive Graphics Card 9600 Gt Nvidia 512mb card PSU 850 Watt Thermatake Black Widow Edition CPU Amd Phenom 9950 Quad Core Processor. i think that pretty much wraps it up. |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 4817 Registered: Dec-06 | That's a great rig Keith, nice job. |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1538 Registered: May-07 | thanks Brad, i'm just starting to have fun with it, i completed all the tweaking and fine tuning yesterday. |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1539 Registered: May-07 | i just found out my store had a diff card on sale so i'm returing the other , for like 45 bucks more i manged to pickup a Nvidia GeForce 9800 GTX + card so it goes in a lil later tonight, maybe i'll get pics up later. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8971 Registered: Jul-06 | That's sweet man. The 9800GTX is quite the step up from the previous card. What operating system are you using? In order to take advantage of that 4GB of ram you need to run 64bit. |
Gold Member Username: Andrew571Stillwater/Edmond, Oklahoma USA Post Number: 2135 Registered: Oct-05 | nice build man. I wish the antec 900 came with the inside painted. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8973 Registered: Jul-06 | By the way I didn't see any pics |
Gold Member Username: LolPost Number: 1188 Registered: Sep-06 | yours turned out better than this guys exspanding foam wasn't good idea |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 4869 Registered: Dec-06 | Alot of that expanding foam has cyanide in it, which is always a good thing. |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1540 Registered: May-07 | i'll get to resizing and upload a few but i'm struggling to the point of no end on 2 things, 1 how in the hell do i get 64 bit to install? i been told a few things i been told vista ultimate should automaticlly detect ur hardware and go to 64 bit, which i wastold the same thing on windows xp pro. i own alot of OS discs, all of them acctually, xp home prem a oem dell of professional, and a vista home prem but if u by pass the serial entering part u can select any vista os, the main issue is how the fudge do i make it go into 64 bit mode? i'm really good with compuyers but just can't seem to make it happen, everyones got a diff answer. also i been through 3 diff cards now, the ati my mobo based card, the nvidia 9600 gt which i exchanged for the 9800 gtx + and in the end the same result, with a dvi to vga adapter, even componet the picture pretty much ether looks like crap on componet or semi ok on dvi to vga adapter with vga cable. i'm pulling my hair out over it, i been down to windows xp, up to vista with still know answer. it's urking me like no other cause on my old computer on the old 256 meg ati the screen looked great on xp, not vista. ether way my picture looks un sharp and i ether get faded bright images or jagged looking icons and stuff idk i'm so lost on how to render this issue. i'm also on a 2 yr old samsung high deff 32 inch lcd tv. helllp! lol thanks for all of the props though, it's my first personal power house build. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8976 Registered: Jul-06 | You have to get the 64 bit Vista disc. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8977 Registered: Jul-06 | As far as the video card issue goes...do you have the latest drivers? Any time you use an adapter you decrease the quality of your picture. If you have the 64 bit vista disc let me know what the error is that you're having and I can probably help you out. |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1541 Registered: May-07 | nah it's not 64 bit disc, the video thing though it's a genric pnp adapter so mybe that's the issue. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8978 Registered: Jul-06 | Well you really need to get your hands on a 64bit Vista disc and install that. If you don't you can't take full advantage of your 4gb of ram. To my knowledge a 32bit can only see and use 4gb of ram, you're supposed to add the ram installed in your dimms and memory on your video card up and see what you get and if you exceed 4gb you definitely need to step it up to a 64bit O.S. Hopefully you know someone with it so you don't have to waste money. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8979 Registered: Jul-06 | Here's the Antec 1200 I built by the way: [IMG]http://i300.photobucket.com/albums/nn4/th3pwn3r/CleanSide.jpg[/IMG] Here's my CoolerMaster HAH 932: [IMG]http://i300.photobucket.com/albums/nn4/th3pwn3r/CoolerMaster%20HAF%20932/100_112 6.jpg[/IMG] |
Bronze Member Username: HeavensLos Angeles, CA Post Number: 22 Registered: Apr-07 | very nice keith! I'll have to post some of my comp up too I have the antec 9 as well. Unfortunately mine is about a year dated (dual core 6400) and only 3 gigs of ram with a 3870 x2 ati card. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 8981 Registered: Jul-06 | http://www.behardware.com/articles/736-4/report-4-radeon-hd-4870s-versus-3-gefor ce-gtx-280s.html If you scroll down to the bottom there's info about the memory issues that you'll run into. |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1542 Registered: May-07 | After some hard work and smashing my bandwith into oblivion. i'm running on 64 bit vista, so here's the pics as promised to tickle ur visual side. last ones a blu ray running from the blu ray drive. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 9010 Registered: Jul-06 | Please clean up that wiring, it's not doing the airflow any favors Keith =/ That pic below is of a sloppy job I did on wiring. |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1544 Registered: May-07 | those were earlier pics before the new graphics card went in and i been pulling parts out at aconstant to adjust this or that. i just got everything acctually fully installed last night. so i shouldn't need to swap stuff out. ether way i understand rob and plan to. i been busy with work to , with the holidays thier pouring on the hours. i'll post new pics up next week or so when i get time, i'm just floored. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 9014 Registered: Jul-06 | Haha, I know the feeling. After working a while on things you just want to use them. That's good that you're getting hours, a lot of people don't even have jobs. |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1545 Registered: May-07 | i been unemployed like a year and 4 months so i know the meaning of broke. it's just dumb luck i found a opening. |
Gold Member Username: Th3pwn3rI compensate... Post Number: 9019 Registered: Jul-06 | Well good for you man, I lost my job about 2 weeks ago now. Hopefully I'll have a good gig kicking in for me in March but that's a long time away. I have my fingers crossed though. |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1547 Registered: May-07 | good luck i hope it all works out for you. it's so bad my state extended un employment a 2nd time. they extended bennifits once already and they claim they might extend it a 3rd time. |
