Pinks
Diamond Member
Post Number: 20959
ok i was watching this show called pinks. its the first time i saw this show. i heard much about it but never watched it.
now can someone explain some stuff for me?
1. heads up.....i know what that is. pretty much a heads up race.
2. 10/50 setup......what is this? they ask what they want to run and they say 10/50 setup. explain please.
3. why do they give one car like half a car length head start and stuff?
Diamond Member
Post Number: 20961
now the mustang beat the camaro by 2 and a half car length so the next race they gave the camaro 2 and a half length head start.
btw its whoever wins 4 races first.
Username: Th3pwn3r
I compensate...
Post Number: 8132
That's how they try to attempt to balance the race or make it "fair" the faster car has to have a disadvantage. It's kind of stupid but it puts it on the driver a bit more. It's a thing of consistency.
Diamond Member
Post Number: 20962
so if i was to race your rex i have to give you 2 car lengths?
Diamond Member
Post Number: 20963
just playin btw rob.
anyways whats a transbrake?
Username: Naledge503
Portland, Or
Post Number: 3701
Yes, and if I were to race your accord, I would have to give you 2 car lengths.
Diamond Member
Post Number: 20964
haha jesse. i smoke tegs all day long.
anyways answer my questions please.
Portland, Or
Post Number: 3702
lol...I was jokin man. I dont know the answer to your question. When I get done with my Teg its gonna be badass. Its gonna take some time though.
Diamond Member
Post Number: 20965
damn lol. well time to sleep. hopefully someone can answer my question.
Username: The_image_dynamic
San Diego, California
Post Number: 4008
From Wiki, since I am not a car guy:
A transbrake is a setup installed in automatic transmissions which places the transmission in first and reverse gears at the same time, effectively "braking" the transmission.
And although I searched and couldn't find anything, I am pretty sure that 10/50 refers to the 10:50:1 compression ratio for the pistons which is the optimum setup for 1/4 mile drags.
Diamond Member
Post Number: 20966
thanks brad. you're the best.
Username: Adddisorder
Palm Beach, Florida
Post Number: 6257
yup, i watch that show. you dont have to have a fast car to win just a good driver and good negotiator.
Diamond Member
Post Number: 20967
i don't think they give up their car for reals though. i mean when they lose they are not as mad. lol. i would be. you spend over 20g on a car just to give it up on tv? i don't think so.
Username: Dsmith07
NC Http://com4....
Post Number: 813
It has a possibility to be real. I wouldnt wanna lost my $20k car, I guess some people got it like that though. None the less a very good show.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 2621
a 10.50 means they are running it in 10.5 seconds...
Username: Th3pwn3r
I compensate...
Post Number: 8139
"And although I searched and couldn't find anything, I am pretty sure that 10/50 refers to the 10:50:1 compression ratio for the pistons which is the optimum setup for 1/4 mile drags."
This isn't totally true, I'm not trying to be an azzhole or anything but I'll put some info out there. A 10.50:1 compression ratio isn't exactly the OPTIMUM bore or ratio for 1/4mile drags. There are LOTS of factors. You could be running N/A(Naturally Aspirated) or you could be running a sh1t load of boost pressure from forced induction from a Turbocharger or a supercharger. Then there's also Nitrous Oxide. All of these will play a role in what is the best compression ratio for your engine.
Username: Th3pwn3r
I compensate...
Post Number: 8140
I spent a lot of time designing engines and the higher the compression ratio the higher power output I was able to obtain of course this was in not boosted or forced induction setups. Basically they were "all motor" engines.
Palm Beach, Florida
Post Number: 6259
rob know anything about alky injection? thinking about doing that to my 460
Username: Kpa2727
Old Bridge, NJ USA !
Post Number: 1314
10/50 usually refers to the quarter mile time as capps said. but, i have seen it also refer to a shot of nitrous and how much each shot or spray equaled. a trans brakes main purpose is to lock the transmission for reving uup the motor to optimum rpm before you dump the clutch and let all that power loose. the reason why a trans brake is used is for 2 things. 1 no standard brake pad system can hold a high powered car while it revs it's rpms up. the car would leap forward, now why is this bad? 2. is why, when being staged to race if you leap or lurch when lined up the person who moved loses automaticlly. the reason? because in drag racing a race can be won by fractions of a sec and quartes of inches. if one car left a little sooner or ahead it is seen as a advantage same thing when someone gets red lighted it means the jumped the gun before the light ever went green. also reason why car lengths are given to whoever lost is thier trying to get the race as close as possible. btw u will also here the term sand bagging. it means when they let off the gas to win a race not going all out. why this is not aloud is cause if they don't push the car then on the last race they beat the guy all out by half a track the loser just got taken.
Username: Rovin
Post Number: 13834
i looked at it when it now came out & absolutely hated it - imo it SUX @SS !
host is such a b\utthead & sometime i feel he screws ppl over aka give em short end of the stick just to get it over & done with
even though if ur super rich i just hate the idea of losing ur ride after all that hard work & time u put into it ...
Username: James1115
Use a simple...
Post Number: 10614
I used to watch it but there is to much laying up going on that makes it stupid if you ask me. You can hear the guys lay off at the end of the race to get the lengths down then they blast them out of the water on the last race. not a big fan personally.
Username: Pitbullguy
The Chicago area
Post Number: 3230
Longo is back FTW!!!
Username: Freezeman_7
FOR SALE, BNIB RD AUDI... USA
Post Number: 2273
actually keith if there was a cluth involved, you wouldnt have a trans brake, you would have somehting called a line lock. which most have anyways.
a trans brake is used only in an auto tranny, it puts the tranny in 1st and reverse at the same time. cause it to lock the rear tires while still being able to bring up the motor. and when you see green you will be able to leave at 5,000 rpm by just letting go of a button. its really an adavantage.
a line lock is used for 2 purposes in drag racing, 1 is used to do burnouts, once you roll through the water, you set the brake pressure at about 750-1200 pounds and keep it pressed while you press the line lock, you can then release the brake and the brake pressure will hold, you can then spin the rear wheels and start your burnout. the pressure will only go away once you release the line lock, the other use for it is, in a manual transmission car, as you no, you cant depress the cluth and put on the brake and step on the gas at the same time, so once your pre-staged, set the line lock to about 300 pounds since you wont have the whole weight of the car you dont need that much pressed, and get it set, when your red to STAGE, bring the motor up to about 3,000 rpm and the motor will drag the wheels into the stage beams, once your there depresse the cluth and deck the motor and release the clutch and line lock button at the exact same time, and your good to go.
we have a NHRA Competition Eliminator Team and an IHRA Pro Stock Team, so i have alot of knowledge on the drag racing subject, i do it every weekend.
hope that helps someone out.
Username: James1115
Use a simple...
Post Number: 10630
WHAT UP PIT!!!!!!!!!!!!
Palm Beach, Florida
Post Number: 6261
chase FTW
Post Number: 2274
lol thanks mat
Username: Kpa2727
Post Number: 1323
well i know a little i was just tryin to give a rough idea of what was goin on but thanks for the info chase. i said clutch but i was refering to what you meant on letting off and the car leaps out. as far as only being on a auto trans , are you sure? cause i could swear i seen a few dozen drivers usuing a trans brake and then shifting through the rest of the gears. maybe it was semi auto?
Post Number: 2275
no, cause with a manual transmission there is no need for a trans brake or TB cause the clutch acts as that in the manual.
most race cars, use a clutchless manual transmission. where the clutch is only used to make the car move forward and reverse. once the cluth is fully engaged the driver can shift gears without depressing the clutch anymore.
