Other than dynamat
Username: Drant19
TX
Post Number: 107
what is there other than dynamat for sound deadening? i know theres something cheaper and better...
Username: Pitbullguy
Ascendant Audio Arsenals, Chicago
Post Number: 2408
paper clips
Username: Th3pwn3r
Post Number:...
Post Number: 6329
There's Raamat, Second Skin, EDead VSE and quite a few others out there. A lot of people go the cheap route and use Peel N Seal but I wouldn't go that route personally.
Username: Drant19
DUB-C, TX
Post Number: 115
what would recommend? and how easy is it to install?
