How to fine my topic
Username: Cherryping0405
HI, kindly help to advise me how to find the topic posted by myself?
Username: Finish22
Post Number: 246
click Edit profile > fill in Username & Password > click Log In > Most Recent Posts
BTW... Apparently the posts listed there only last for several (?) days.
Username: Finish22
Post Number: 253
After doing some serious investigation, this is what I found out :
Posts listed on "Most Recent Posts" list last only for about a week.
So if you want to look for an older post, you'll have to keep
a permanent record of all your posts.
For this, go to "Edit Profile" , then to "E-mail Notification" and check box
"My Own Posts". Click on "Save Profile Changes".
Doing this, you'll receive via e-mail a copy of all your posts.
Then, using Ecoustics' Search Feature (located on top of page)
and with key words such as the post's topic, username, date, etc.
maybe you'll get lucky and find your old post.
If it sounds a bit complicated, that's because it surely is.
Need to Register?
Forgot Password?
Enable HTML code in message
