Admin - Horizontal Scrolling Issues
Username: The_image_dynamic
San Diego
Post Number: 3135
What happened to the pages on Opera? All of a sudden the last few days the right margin is off of the page and has to be scrolled over. It is fine on IE but I never use that for obvious reasons. Seems that something has been changed in CSS to cause this. Please look into it.
Screencap here: http://tinypic.com/view.php?pic=6x1lpjk&s=1
Thanks.
Moderator
Username: Admin
Post Number: 3066
We didn't make any CSS changes. I'll have to investigate further.
Is the problem on all pages of the forum? Are other sections of the site OK?
San Diego
Post Number: 3136
Yes, every page is affected. It starts out "normal" and then a half second or so later it jumps to about 30% off the screen to the right side as shown in the screencap.
I am assuming that users with Apple's Safari browser are experiencing the same thing since both Opera and Safari use (some of) the Konqueror coding/rendering engine that uses "padding" instead of margins as the example below illustrates:
#rightcolumn {
width: 196px; /* RC width (ie fullwidth minus 20 for padding) */
padding: 264px 0px 0px 0px; /*
I have never seen this happen on any other site and since you say that nobody has changed anything recently, it must be a bug in the forum software that altered the CSS.
Thanks again.
Username: Naledge503
Http://com4.runboard.c...
Post Number: 2424
So whats going on with this? Its very annoying and this is the ONLY site that has this issue.
Moderator
Username: Admin
Post Number: 3148
Safari on a Mac does not have problems. I will have to test Safari and Opera on a PC. Hopefully I can get this resolved by the end of the day.
Thanks for the reminder.
Moderator
Username: Admin
Post Number: 3158
Is it fixed now? We just changed some code.
Username: Dr_dss
Post Number: 420
Yes right margin okay now on Opera
Post Number: 2445
No its not fixed yet. Here is a screenshot of what is going on. You have to scroll way over to the right to view the post's.
http://i58.photobucket.com/albums/g263/Naledge503/Range%20Rover/screenshots/escr eenshot.jpg
Username: Dr_dss
Post Number: 421
Yes it is. I had the same problem you speaking of up until today.
I don't have the problem with Opera.
http://img140.imageshack.us/img140/7271/marginqv3.gif
Post Number: 2449
Its not fixed on my end. Are you on a Mac or a PC?
Username: Dr_dss
Post Number: 422
pc winxp
Post Number: 2457
Same here, so I dont know whats up. I know that Brad Warren is still having the same problem.
San Diego
Post Number: 3214
Yes it is fixed. Great job Admin and thank you!
Post Number: 2465
Its all good now. Thanks admin
Need to Register?
Forgot Password?
Enable HTML code in message
