To: Admin - Problems logging in...
Username: Ojophile
ON
Post Number: 156
To admin:
Since last weekend Nov. 27), I've been having problems logging in. I sign on with my usual user name/ID and password, but I don't see the notification, "logged in as ..." Neither do I see my user name and pwd (****) in the post-message box. Anyone have the same problem? This is happening on any PC that I use.
See below. I'm already logged in but I don't see my user name. I have to type it again in order to post this message.
Please advise and/or correct the situation.
Thanks,
Don
Moderator
Username: Admin
Post Number: 171
We are currently investigating your login problems
Moderator
Username: Admin
Post Number: 174
There are two components to having a member's username and password filled into the form. Cookies and Javascript must both be enabled in the browser, so that the information is filled in.
Some pop-up blockers or a filtering proxy might also be a cause of the problem.
Entering in the correct username/password manually in the boxes when posting will always get your posts added.
Username: Ojophile
ON
Post Number: 172
To Admin:
Thanks, but I still can't log in and stay logged-in. I've enabled all Cookies including 3rd party ck.. JavaScript has always been enabled.
On another forum that I'm a member of, I'm able to log in and remain so until I exit my browser.
Please re-investigate and advise. As I said, the problem exists regardless of the PC that I use.
Thanks,
Don
Moderator
Username: Admin
Post Number: 175
Try clearing the cookies in your browser.
Also make sure that your user profile, has the box checked: "Remember my username and password in a cookie."
https://www.ecoustics.com/cgi-bin/bbs/board-profile.pl
Username: Ojophile
ON
Post Number: 175
To: Admin
I must have unchecked that box somehow while reviewing my recent posts.
It works now. Thanks a lot!
Don
Username: Eskimo3
Post Number: 117
How do you do that again,I'm having the same problem.I know I can just look up there but I don't want to have to look through all those other posts.Admin,help!!!!!!!!!!!!!!!!
Username: Eskimo3
Post Number: 130
Hey Admin??????? You in there?
Moderator
Username: Admin
Post Number: 205
Make sure that your user profile, has the box checked: "Remember my username and password in a cookie."
Cookies and Javascript must be enabled.
Username: Eskimo3
Post Number: 140
I had no idea what the cookie was so I didn't check it, can I change it?If so, how?
Moderator
Username: Admin
Post Number: 207
A cookie is a small file which is created on your computer when you login that remembers your login information.
Most web browswers (e.g. Internet Explorer) will automatically accept cookies. You can manually disable the feature within your browser. As long as it's enabled you shouldn't have to check anything.
Username: Eskimo3
Post Number: 154
Can I change it and if so, how?
Moderator
Username: Admin
Post Number: 209
We have enabled it for you in your profile.
You can edit your profile at this link:
Username: Eskimo3
Post Number: 170
Thanks but I'm still not logging in, and what do the little trash cans next to my posts mean?
Username: Eskimo3
Post Number: 206
Oh, my mistake it's working now, thanks! :-)
