Username: Altinem Post Number: 1 Registered: Aug-04
Saturday, August 21, 2004 - 23:32 GMT i was wondering if there is way to make jtag port for dp311 and run dp311 with magic card.
Username: Jmill1948 Chester,
Va
Usa
Post Number: 188 Registered: Apr-04
Sunday, August 22, 2004 - 02:59 GMT check the magic card forum
Username: No_bser Post Number: 8 Registered: Aug-04
Sunday, August 22, 2004 - 03:02 GMT absolutely not! can't be done
Username: Altinem Post Number: 2 Registered: Aug-04
Monday, August 23, 2004 - 00:17 GMT i found jtag pin number for sti5517 but i cant see the pins on the board because pins stay under the chip.what i am thinking is if we remove the sti5517 and locate the traces for those pins and connect a jtag.is it possible or not?
Username: No_bser Post Number: 11 Registered: Aug-04
Monday, August 23, 2004 - 04:21 GMT if you have to play with, then yes you can do that, but i would hesitate doing it... still not worth it... again, it's all about testing.
