Have a 70 inch Sharp TV on the blink
Username: Tickler
All I get is a black screen and a flashing upside down V at the bottom edge of the box. don't know whither to take it to the dump or try to get it fixed any suggestions live in the Brechin Orillia area
Username: Magfan
Post Number: 3262
Most professional techs will provide an estimate of 'cost-to-fix' which would be deducted from the final bill IF you get it fixed.
Somewhere in the manual / or online helps, MIGHT be what that symbol means. My SONY would flash its power led in a certain pattern indicated it wasn't happy in some regard. Like '3 blinks, space, 1 blink' might have meant it needed a new lamp or the cooling fan had a problem (clog?)
IMO, I'd set 'maximum' price for the fix, which if exceeded would mean you PAY for the estimate and go buy a new set. It MIGHT yet be something simple and easy to fix.
Need to Register?
Forgot Password?
Enable HTML code in message
