55" Vizio TV Remote
Username: Tophat1
I have a E55OVL Vizio that I had lost the sound on all three HDMI ports. Got a new main card through a supplier from Vizio. This is suppose to be a brand new card not rebuilt. Anyway the TV works fine now sound and everything. The problem is now the remote does not work were it worked fine before. I just use this remote to switch imputes for when I want to used my DVD Player. I put new Batteries in it and even tried a different remote for a 42" Vizio. Nothing works the TV. I'm hooked up to Direct-TV. All of the side buttons on the TV work fine but would rather have the remote working. Any help? Dennis
Username: Tophat1
Just so if anyone else has this problem don't forget to hook the sensor back up. That what I did . Took it back apart and TV works fine.
Need to Register?
Forgot Password?
Enable HTML code in message
