Whats next
Username: Jay228
Windsor, Ontario Canada
Post Number: 65
So the last receiver I owned was pansat.. now i am looking to buy a new receiver.. i am going towards dreamlink v4.. does anyone how it is ? or is there anything better?
Username: Lklives
Post Number: 17084
Drop a hit of acid and U will see more then than on FTA..FTA is dead unless its limited local channels that rabbit ears will get ya... I'm guessing U fell of the planet the past few years..
If ya really want cheap TV, share a sub on Directv...same advice I've said for years..
Username: Jitu
Post Number: 1569
Try Jynbox HD cheap and good FTA receiver read reviews on Google.
Username: Jay228
Post Number: 66
they both cost around the same price :/
http://ontario.kijiji.ca/c-buy-and-sell-electronics-Jynxbox-Ultra-HD-v2-FTA-Sate llite-receiver-Jynx-box-JB200-Module-W0QQAdIdZ452433638
http://toronto.kijiji.ca/c-buy-and-sell-electronics-New-DreamLink-HD-Version-4-R eceiver-Dream-Link-High-Definition-W0QQAdIdZ366949285
is one better than the other?
Username: Code69
Post Number: 74
diddy..shut up!
Username: Athena_
Post Number: 93
to funny Applebee's
Username: Jitu
Post Number: 1570
My opinion Jynxbox-Ultra-HD
Username: Jitu
Post Number: 1571
I do not understand why no one is helping Jay123
Username: Mrskullz1
New York
Post Number: 2112
Honestly, your only option is to go for some private servers out there. BUT be careful when you go this route. Sub sharing between friends IMO would be the best option. Yes, you pay a little more but it is totally worth it. You do not need to worry about servers going down, channels freezing, black outs, and most of all, you are safe.
There are private servers out there which are really cheap.
If you have a HDTV (who doesn't these days) and live on the west coast, get a HD box. More private servers support satellites located on the west coast, than on the east. Some areas on the east can NOT get 129 (this is were most HDs are). If you are not in a clear footprint for 129 and can't find any provider supporting 72.7, then don't waste money on a HD box. Get any SD box that can an ethernet port.
If you are OK with hiccups, intermittent freezing, ECMs, etc., then go for the private server option. It's cheaper but you get what you pay for.
If you want quality, sub share with friends/family. The more you can get, the cheaper it gets.
Need to Register?
Forgot Password?
Enable HTML code in message
