RCA not receiving signal from cable box
Username: Dfox1272
OXFORD, Alabama (AL) United States
We have an RCA 52" HDTV DLP projection. We bought it in 2006. We had a problem with the color wheel, then the bulb went out now it is not receiving a signal from the cable box. Any ideas on how to fix it? Is it worth fixing? We swtched the cables and the input but it still doesn't work. We can hook it up to DVR and watch recorded shows. We hooked another TV to the cable box and it works fine.
Username: Ieee488
Post Number: 684
If you can watch recorded shows from the DVR on the TV, then most likely the tuner on the TV is bad.
Need to Register?
Forgot Password?
Enable HTML code in message
